04-22-2016
07:43 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
04-22-2016
07:43 AM
If you are using the sheet set features, you should definitely NOT use that LISP program. The sheet set manager manipulates the layers for the views and needs to be able to vpfreeze and vpthaw layers when multiple model views are added from different drawings. By messing with the layers, you are conflicting with that process. Working from memory here, but the sheet set manager already puts each xref on its own xref specfic layer so that layer 0 objects can be managed properly.
Architect, Registered NC, VA, SC, & GA.
