- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Need a solution. And before anyone jumps to conclusions, VISRETAIN is set to 1. We are having a problem and I think we may have isolated the issue but I cannot completely resolve it. When we open drawings containing views and viewports created with Sheet Set Manager, it freezes layers within the viewport. Some freezes layer 0, drawing layers and xref layers of the viewport layer state.
I've seen multiple hits on the internet with this problem but no solutions. Below is one reference:
We are running an xref layer name and lock all xrefs lisp routine in our AutoCAD startup. I have found that if I disable this lisp and open these problem drawings the layers do not get frozen within the viewports. I am curious if others that have had this problem were running a similar lisp.
Our work flow for creating these drawings containing this issue are as follows:
- Create a new Sheet Set.
- Link DWT template for drawing creation.
- Map models folders, etc.
- Start new sheet.
- Drag and drop model views from xrefs into new sheet.
- Save & close.
- Open new drawing through sheet set manager or through AutoCAD open command.
- Once drawing opens the border, viewport and objects within viewport appear for a second then dissappear.
- If we manually thaw and correct all layer states within the viewport then save, close and reopen everything works fine there after.
Manually creating drawings without sheet set manager by choosing a new template, manually creating viewports, manually attaching xref's, manually setting viewport properties, saving & reopening works fine.
Another difference I noticed was that sheet set manager work flow seems to create numerous layer states. Manual work flow does not create these.
Also, in the layer state manager dialog box there are two check box settings for "Restore Options"; "Turn off layers not found in layer state" and "Apply properties as viewport overrides".
- Viewports are locked
- Running AutoCAD Mechanical 2016 SP1
¡Resuelto! Ir a solución.
