john.vellek
en respuesta a: Anonymous
HI hanif.yasrobi,
I have been looking at your point data and it does appear that there are common points shared by the various "planes". What I don't see are spot points that would help to establish irregularities in the faces of the planes. I think this is what you were referring to as "deformations".  If you don't have these points I am not sure that you can actually get a true representation of the condition.
So, instead of using solids created by LOFT (which according to your points is correct), why not place a 3dsurface mesh at each of the faces so you could manually manipulate the appropriate "interior" vertices?
If this does not suffice, I am at a loss of what else to suggest. I am not an expert in creating surfaces from topo or contour points which is what you are basically trying to do. This type of feature would be more appropriately accomplished in Map or Civil 3D.
Please hit the Accept as Solution button if my post fully solves your issue or answers your question.
John Vellek
