- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
To add to this thread;
If you are running a lisp for this method of inserting a relay coil there was a slightly similar issue that was posted in the lisp forums, you can check it out here.
If you are still running into the issue I would do the following;
- Clean up all files having this issue
1. Run RECOVERALL, at the command line and select drawing, save drawing and close.
2. Run RECOVER, at the command line and select drawing.
3. (-)PURGE > Regapps > Enter>No
4. (-)PURGE>ALL> Enter>No
5. AUDIT> Yes
6. PURGE > Select Purge nested items> Select Automatically purge orphaned data > Purge All
7. (-)SCALESEDIT
8. CTRL+A > OVERKILL (Warning: use this command with caution, running the command modifies your geometry by deleting objects you may need. Save a copy of the original file in case of any unwanted changes. )
- Make sure all lisp routines and paths are correct
Sarah Emmsley
Technical Support Specialist
