- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Thanks for your comment but it seems you have tried to just drew something which is look like the shape that i want but the problem or the point is
these are not the points on the circumference line of a circle of a rectangular these are coordinates which not look like this on the next steps these will defomr more and then they will not fit on the lines which you drew.
if you read my explanation the different layers which i have made is just different outputs which is imported to autocad with a modified command as you see it is not working perfectly.
If you have any solution for the layer which called point cloud out of edges let me know this is the deormation of rockmass on the edges and i have to prepare a solid out of it and bring it back to Abaqus as a part
Best regards
Hanif
