- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Hello John,
First of all sorry for replying that much late I was on a vacation. it is very kind of you the you are going to help me, it would be great if you can solve the problem because it is not easy to solve for me.
Now back to work, I will explain more in detail to give you an overall view what i am doing now and what is my target:
All of these different layer is an export from ABAQUS program with a modified auto cad code which read the points from a text file ''exported from ABAQUS'' and gives us this as points or poly lines which is connected together in a crazy way ![]()
This cad file is a representative of deformed rock mass around the tunnel I have to do the same procedure for each part in total 12 parts.
Now let’s talk about just this part, left side of this object as you also mentioned is somehow seems not ok, but it is correct because on the program left side of the model is fixed in the boundary conditions of the model and it cannot move therefore it looks like this.
My favor is to find a solution to make a solid from ''point cloud out of edges'' layer or ‘‘point cloud out of edges'' layer because it will be very accurate solid.
These points are the representative of the deformed rock mass at that exact coordinate.
I have found one solution which is working but it is not accurate:
I import front face and also the back side of the rock mass drew a line as an alignment and makes a solid with sweep order giving the path which is the line.
it gives me a nice solid which looks ok but is not accurate. The problem is I am connection front and back point and refusing middle points of the rock mass which could deform as well also after some steps of excavation will be more deformation on this path which will be ignored by this method.
Thanks very much in advanced and again sorry for late reply
Best regards
Hanif
