04-18-2016
03:22 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
04-18-2016
03:22 PM
Thanks John for your work on this. It appears you are taking the same work-arounds I did to produce something that is close to what it should do.
Your suggestion may work, however, you would have to put in all the data for each plant for every label. It would be much preferred to be able to change the plant ID and by the way of the external link, containing the master list of plants, be able to fill in the table.
I've attached a sample drawing and excel spreadsheet you can use to play around with.
Thanks.
