pendean
en respuesta a: AlexFielder
According to HELP the command CLEANSCREENON does "...The screen displays only the menu bar, the Model and layout tabs at the bottom of the drawing, the status bars, and the command line."
CLEANSCREENOFF command (or the statusbar button, or CTRL+0) ought to get you back into 'standard' screen. Does it not, instead of closing AutoCAD?
It may require a new patch from Autodesk if missing, FILETAB is being reported as troublesome earlier in the same thread.
