dpalmerVQ54W
260 Vistas, 1 Respuesta
Cosshairs do not respond after PC screensaver has been on
I am using ACAD 2014 on a Panasonic tablet, with the screen extended on to a HDMI monitor.
I am finding that the cross hairs are not responding to the mouse after the screen saver has gone off. The mouse pointer moves over the icons ok and they can be selected, however the as I move the mouse to the drawing area the pointer disappears and the crosshairs do nothing.
David P
AutoCAD 2021
TheCADnoob
en respuesta a: dpalmerVQ54W
IT may be an issue with your video card driver. You can updating or rolling it back. You can also try toggeling graphics acceleration.
in the short run i have seen that sometimes changing some of the display elements will make the crosshairs respond. You can movinging around the viewcube and see if it brings it back. Also changing visiual styles (i.e. cahnge from wire frame to conceptual and back) may bring it back as well
CADnoob
