Alfred.NESWADBA
en respuesta a: Anonymous
>> I don't know how to check which points are 19 or 20 and 1 or 2?
Select the object then look to the properties Window, there you have the chance to step through the vertices/control points and every selected point gets a marker:
To step forwards and backwards use the small arrows on the left side of the field with arrow up/down symbol.
>> and how to remove the additional points
Start command _SPLINEDIT, select this spline, then use option Edit vertex ==> Delete
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
