04-15-2016
09:17 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
04-15-2016
09:17 AM
@john.vellek wrote:Hi schweitzernic,
Let's try this since I cannot duplicate the error on my side.
Try following the steps I went through: (AutoCAD 2016)
CUI
Rt-click Workspace>New Workspace>Test
Select Test Workspace (set it to current)
Then move down the tree and go to Ribbon>Tabs
Rt-Click>New Tab>Test1
Rt-Click>New Tab>Test2
OK your changes. Does the new workspace appear? And, do both Tabs show up?
If so, you can simply rename and then add panels as required.
Please hit the Accept as Solution button if my post fully solves your issue or answers your question.
Tried this and the Test workspace is active but the ribbon says "The Ribbon does not have any tabs or panels currently loaded."
