- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
And, accidentally, I found another difference. I own a 3d-mouse, called "Space Explorer" from "3DConnection". If I work in "wireframe" view I can rotate the model in all axis. If I work in "2D-wireframe" it is limited to pan and zoom. In former versions of the driver for the 3d-mouse I was able to limit the movement to pan in the driver options. The new driver does not have this option. I think, there is a strong cooperation between AutoDESK and 3dconnection. In the first times of this 3D mouse you had to install a special AutoCAD driver for it. On the other hand, 3DORBIT inside AutoCAD can rotate the model regardless of 2d-wireframe or not. If you use 3DORBIT, 2d-wireframe is temporaryly disabled. You can see it on the upper left corner. "2D-wireframe" changes to "wireframe" during operation with 3DORBIT.
Workstation: Ryzen 9 5950x@ 4,20GHz 64 GB RAM, Nvidia Quadro P5000, Win10 Prof.
Rendernode: AMD Threadripper 2990wx@ 3,20 GHz 64 GB RAM, Win 10 Prof.
Autodesk Building Design Suite Premium 2021, VRay 5, ForestPack, RailClone, RichDirt, KStudio ProjectManager....
