Alfred.NESWADBA
en respuesta a: Anonymous
to give the focus to an application is a job Windows has to do, so you need to search for API function that makes the application pushed to the foreground.
Try that (lines to be changed compared to the previous code are green):
Option Compare Database
Private Declare Function BringWindowToTop Lib "user32" (ByVal hwnd As Long) As Long
Private Sub CMD_OPEN_Click()
    On Error Resume Next
    Dim tAcadApp As Object
    Set tAcadApp = GetObject(, "AutoCAD.Application")
    If (tAcadApp Is Nothing) Then
        Set tAcadApp = CreateObject("AutoCAD.Application")
    End If
    If tAcadApp Is Nothing Then
        Call MsgBox("AutoCAD not responding or not starting")
    Else
        tAcadApp.Visible = True
        Call tAcadApp.Documents.Open(DrawingName)
        Call BringWindowToTop(tAcadApp.hwnd)
    End If
End Sub
HTH, - alfred -
Alfred NESWADBA
(not an Autodesk consultant)
