stevetamplen
en respuesta a: cturlington
I think the next steps should be to try resetting AutoCAD to defaults, then if that doesn't help, try a new profile.
1. Start by backing up any customizations, then resetting AutoCAD:
How to reset AutoCAD to defaults
2. Create a new Windows user profile. Give it Administrative privileges, then log out of the current user, and log back in as the new Admin user and check AutoCAD to see if it is functioning correctly.
Also, can you please tell me which Operating System you are using, and if the installation has ever worked correctly since you installed it?
I probably should have asked you that right off the bat.
Steve Tamplen
Technical Support Specialist
