en respuesta a: rkmcswain
I have all the original blocks inside of one drawing file that I am trying to work through this process with.
I just tried the BATTMAN command also; see the attached screenshots...no dice, the minute I copy to the tool palette, and try dragging it off the tool palette, it all goes to hell.  You can see that the ASSY TAG has reverted to X, and the position of that X is off from the original block.  Again, these problems do not appear when inserting from the ribbin, they only keep happening after using the **** tool palettes.
