stevetamplen
en respuesta a: cturlington
I would not assume anything.
You can check to see if Service Packs are installed by opening AutoCAD, and clicking on the dropdown in the upper right hand corner, just to the right of the question mark, and choosing ABOUT Autodesk AutoCAD 2016. The window that comes up should have Autodesk AutoCAD the upper left hand corner, and on the second line should have the version number, then AutoCAD 2016 SPx if there is a Service Pack installed.
Also, you should try using the standard AutoCAD template and see if that makes a difference.
Steve Tamplen
Technical Support Specialist
