en respuesta a: Alfred.NESWADBA
>>Which command prompt? MS-Access does not have a command prompt afaik
the windows command promt...
>>don't use vbMaximizedFocus as this could change the application window.
If I just could get the command in Access: Shell "C:\Program Files\Common Files\Autodesk Shared\AcShellEx\AcLauncher.exe \\MARK-SERV2\Tegning\acad\ARKE\E00\000-199\400E118​A.dwg", vbMaximizedFocus, to work I would be happy so far :cara_con_una_leve_sonrisa:
-Frederik
