en respuesta a: Anonymous
Just realized this happens with the Erase command (probably specifically)... I was using PE and selecting lines to join for segments and noticed the lines I was selecting was growing blue and I can see them slightly better... The blue effect is seen with the Move command too. hmmm... there has to be some way to make this act normally again... I don't have a copy of the older version of AutoCAD to try this one to see the difference.
Attached is an example of it being blue. But I still want to fix the light grey or thiner line issue.
