Kent1Cooper
en respuesta a: Anonymous
@Anonymous wrote:
Is there have any code or can be change 2d to 3d by any settings....please tell it immediately ...
Welcome to these Forums, by the way!
Some people obviously think that you mean you want to change some 2D object to a 3D version of itself.  If you mean, instead, that you want to somehow change from a 2D drawing mode to a 3D mode, I think @jggerth's reply is your answer -- there is no such setting.  AutoCAD keeps track of everything in 3D, and if you don't want 3D, you can limit what you do to 2D by merely not giving anything thickness or elevation, nor using Z coordinates [other than 0] in drawing anything.  You can switch to drawing in a 3D way any time you choose, without changing any setting, and you can make 2D things into 3D things with various commands already mentioned, among others.
Kent Cooper, AIA
