en respuesta a: Anonymous
You want to make a 3D object from something that is 2D?
The quickest way is to select the object, open up the properties dialogue box and select "Thickness". This will give a 2D obect DEPTH. You can do this with just about any object in Autocad. To look at the object in 3D, hold down the Ctrl key on the keyboard and depress the scroll wheel on your mouse (if it has a scroll wheel) and move your mouse around.
