- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Dynamic Block / ATTDEF issue
Hi all,
I have an issue with a dynamic block that I am creating. Essentially it is a two line dynamic block for a title and scale option with a visibility parameter to switch between scales. I created one previously which works fine for a multitude of scales. This time I wanted the title line to be MTEXT so I slected this option and also unlocked it so it wouldn't cover the scale text.
The problem is that even though all tags are different, the unlocked MTEXT for 1:100 visibility scale is visible at all scales not the one I require. I have ensured that the object visibility is correct for each scale but no joy.
I have used the ATTSYNC variable but that doesn't affect the dynamic block.
The file is attached for anyone to look at.
Yours in anticipation,
bigroo
