- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Dynamic Block / ATTDEF issue
Hi all,
I have an issue with a dynamic block that I am creating. Essentially it is a two line dynamic block for a title and scale option with a visibility parameter to switch between scales. I created one previously which works fine for a multitude of scales. This time I wanted the title line to be MTEXT so I slected this option and also unlocked it so it wouldn't cover the scale text.
The problem is that even though all tags are different, the unlocked MTEXT for 1:100 visibility scale is visible at all scales not the one I require. I have ensured that the object visibility is correct for each scale but no joy.
I have used the ATTSYNC variable but that doesn't affect the dynamic block.
The file is attached for anyone to look at.
Yours in anticipation,
bigroo
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
For attdefs in dynamic blocks you have to set the lock position value to yes for each one then attsync.
I did that for your block and it works fine for me.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
If I set the lock parameter then there is no point in having MTEXT as it will cross over the second line that I have.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Ha! That is such a brilliant answer. It doesn't need to be an incredibly technical solution in every case does it ![]()
