252 Vistas, 2 Respuestas
ERASING MULTIPLE BLOCKS
I've been working on a job where I need to show multiple copies of a block.
In this case I'm showing multiple sets of parking spaces for a parking lot.
Well as I decide to make changes and remove some of the blocks so that I can rearrange the lot I'm having trouble picking multiple blocks to delete.
What's happening is that when I'm zoomed in close enough to be able to safely do a crossing to select items, if I also pan while in the middle of the process it will only delete the blocks that are visible on my screen.
Dropping the ones that I had selected before pan further along in the lot.
I've been using Architecture 2016 if it makes a difference.
Is there a setting that can be adjusted to keep this from happening?
It's just a nuisance!
Thanks for any help.
Radar
