john.vellek
en respuesta a: Anonymous
Hello @Anonymous,
I apologize for not seeing your post earlier.
I am looking at your example file and I am not quite sure what you mean by performing a Sweep to obtain your solid. Is the 3Dpline in the first or second layer the intended sweep path? or, are you trying to loft between polylines?
It appears from the "test" layer that you are indeed creating the solid but the left (back) face is the one that's not turning out as expected. Is it possible to add the additional face by using the edges of the solid? If my assumption(s) are incorrect, please correct me.
Can you send me a sample Screencast or series of pictures that illustrate the steps you are following and your desired output? I would be happy to help you if you can provide a bit more information.
Please hit the Accept as Solution button if my post fully solves your issue or answers your question.
John Vellek
