726 Vistas, 1 Respuesta
2D Model Space
I've just installed 2017 Autocad. What I'm trying to find is a parameter that will set the 2D model space to end above the Command line. As it is now, the Command line is considered transparent, which gives you more realestate in model space, but it seems like I'm constantly panning up so I can select something behind the Command line. I would rather loose that bit of work space.
Thanks in advance
John
