03-30-2016
03:53 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
03-30-2016
03:53 PM
@Anonymous wrote:
pendean,
How would you do that? Is it in the save as menu?
What pendean said is right.
Alternatively, you can simply enter "export" without the quotation marks in command line.
This is one of the great advantages for using AutoCAD. Simple and straightforward.
- You may also explore the HELP menu for all AutoCAD commands.
BTW I use Mech version all time but rarely convert drawings for non-Mech users.
Did you try "save as" then in the long list of "File of type" choose "AutoCAD 2014 drawing (*.dwg)"?
Please mark "Accept as Solution" and "Like" if my reply resolves the issue and it will help when others need helps.
A circle is the locus of a cursor, starting and ending at the same point on a plane in model space or in layout such that its distance from a given coordinates (X,Y) is always constant.
X² + Y² = C²
X² + Y² = C²
