03-23-2016
01:19 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
03-23-2016
01:19 PM
Writing to Virtual Memory is much slower than writing to Physical Memory, especially if the Paging File is stored on a slow hard drive rather than a fast solid state drive. So when the computer runs out of RAM and starts writing to the paging file, everything will slow down.
AutoCAD is giving you a warning in the command line about low memory, which seems to be in line with the size of files you're working with, so I think your solution is to add more physical memory for those users, or break the files up into smaller pieces to work with. It sounds like you'll need at least 24GB of RAM, but I'd go ahead and do at least 32GB to be safe.
Work: AutoCAD 2022.1.3, Windows 10 Pro v22H2 64-bit, Intel Core i7-8700K, 32GB RAM, Samsung 960 Pro SSD, AMD Radeon Pro WX 5100, 3 Dell Monitors (3840x2160)
Home: AutoCAD 2022.1.3, Windows 10 Pro v22H2 64-bit, Intel Core i7-11700, 64GB RAM, Samsung 980 Pro SSD, NVIDIA Quadro P2200, Dell Monitor (3840x2160)
