- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Display area inside a closed polyline
This sounds like a simple question: I have a .dwg file with elevation contours. All of the contours polylines are "closed". The areas of smaller contour shapes show up in the properties (i.e. 1250 square feet). However, when the area of certain closed contours gets larger, the properties table does NOT show the area. It just disappears from the Geometry menu in the properties table. I've tried to display the area using the FIELDS among other unsuccessful fixes. Any ideas?
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Post sample drawing.
AutoCAD version? Win OS? Computer hardware?
Area Object Link | Attribute Modifier | Dwg Setup | Feet-Inch Calculator
Layer Apps | List on Steroids | VP Zoom Scales | Exchange App Store
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi and welcome to Autodesk forum,
would you post some of these contours lines as a CAD drawing?
Imad Habash
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Could you try increasing your PROPOBJLIMIT and see if it makes a difference.
CADnoob
