642 Vistas, 8 Respuestas
Dialog boxex
Hi
My dialog box in commaneds like- hatch or array isnt opening.
He only gives me the options in command line
tried as i search here fielddisplay and change to 1- but its not working
efrat
M_Hensley
en respuesta a: Anonymous
Make sure HPDLGMODE is set to 1
en respuesta a: M_Hensley
thanks ! its helped regarding to hatch- array is still not opening...
parkr4st
set sysvar FILEDIA to 1
rkmcswain
en respuesta a: parkr4st
FILEDIA only controls FILE DIAlogs.
WHATS IS- sysvar FILEDIA to 1
I WROTE ON THE COMMANDE LINE FILEDIA AND ITS ON 1
rkmcswain
ARRAY does not have a dialog. You can control the options of this command in the Ribbon.
If you wish to use the older ARRAY command, run the command ARRAYCLASSIC.
THANKS A LOT!!!!!!
rkmcswain
Don't worry about FILEDIA, it has nothing to do with your issues.
