Kent1Cooper
en respuesta a: Anonymous
What bounds the pattern to the right and above and below?  That pattern certainly looks as though it could be defined pretty easily into a Hatch pattern, in which case you could just apply it within a boundary, and wouldn't have to lay it in over more area than you need and then cut it back.  Even without defining all of it into one pattern, you could use a parallel-lines pattern three times with a little care about the scaling, rotation and origin, and get the same effect.
Kent Cooper, AIA
