- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
To provide an update on this topic and thread. The following AutoCAD versions have been tested with Windows 10.
• AutoCAD 2016 is supported with the application of AutoCAD 2016 SP1.
• AutoCAD LT 2016 is supported with the application of AutoCAD LT 2016 SP1.
• The 2016 version of most AutoCAD-based verticals should be installable and perform as expected on Windows 10
Autodesk product versions of 2012 and earlier are no longer supported and are not included in considerations of Windows 10 compatibility.
The English language versions of AutoCAD 2015 and AutoCAD-based verticals should be installable if you have received the Windows 10 update, KB3081448 or later.
Other AutoCAD language versions and language packs can be installed if Windows 10 update, KB3105210, is applied prior to installation.
DWG TrueView 2015 can be installed if Windows 10 update, KB3105210, is applied prior to installation.
The 2013–2014 versions of AutoCAD products will not be supported on Windows 10. For all links and further information on this topic please read over the AKN Article.
Sarah Emmsley
Technical Support Specialist
