TheCADnoob
en respuesta a: rross
If your old work space is still avaliable you can transfer it from you last AutoCAD version : https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Transf...
f that is not an option you will have to use the CUI
type the command CUI. If you are simply moving a few things around it may not be to hard but the more advanced your customization the more indpeth you will have to get.
Specific to your need i might create a custom panel and import all the command you want (frequently use) to it.
type CUI
And add a Tab
Got to the panel section and add a panel
Find the command you want and drag it to your panel
Drag your panel to your tab
at the top of the dialog select transfer tab then select new customization file.
Then transfer you newley created tabes and panels to your customization file and save and applyCadnoobcustom6.png
Make sure (if your panels/tabs arent showing) you make the the panels visible to your workspace. Right click on an empty space on your ribbon.
Viola
CADnoob
