Alfred.NESWADBA
en respuesta a: Anonymous
>> I'm more looking for a function like the registration function
I would not know of a way to do that automatically.
In case you do you have Map3D or Civil3D available, there you can find command _ADERSHEET where you can define pairs of points (source position / destination position) and then a module for affinity transformation is doing the job.
Can you give us some background info's about this workflow? Where do the data come from, which type of objects stand these circles for and what will be done after the transformation (and which accuracy is needed)? Maybe that can bring up some additional ideas.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
