842 Vistas, 2 Respuestas
Align circles as good as possible
I have two datasets of the same objects, both meausered with a different technique. The datasets are drawn as different circles. Each circle has a correspondig circle (meausered with the second technique), but not with the exactly same position or radius (approximate the same).
I search for a funciton or method to align both datasets as good as possible, however the standard 'align-function' doesn't satisfy. I'm more looking for a function like the registration function when you are working with pointclouds (best alignment of two clouds), but in this case I'm working with circles instead of points. I need to fit the complete dataset of technique one (black cirlces) to the complete dataset of technique two (red circles) as good as possible.
Thanks in advance.
