stevetamplen
en respuesta a: Anonymous
Hi Paul;
I can't see the top of the window, but capture2 appears to be the Edit Layer State dialog box, where you can make changes to an existing layer state.
So the workflow is:
1. Put layers into the state you want them displayed (some on, some off, a couple frozen, etc.)
2. Create a Layer State from that configuration
3. Give it a name describing that configuration (Wiring, Piping, Walls, etc.) and put in a short description if needed
4. If you made a mistake, or decide you want to make a change, edit that Layer State and make changes to fit what you want displayed
I recommend you watch the 2 Youtube videos (thanks jporter!) as they are both good instructional videos for how to use Layer States.
Steve Tamplen
Technical Support Specialist
