en respuesta a: pendean
I do believe it was an issue with my video cards capacity, as when I turn off the hardware accelleration inverted arc drawing seems to have stopped.
The problem with using the "REGEN" command was that it was not an issue of 10 to 15 instances, the arcs would redraw incorrectly every time I would adjust the zoom levels leading to regenerating hundreds of times a day, which was not something I needed to do in the 2015 version.
Thanks for your help.
