- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Dear support,
My tutor is not able to open the dwg file that I have created
and sent him. Is this due to the use of the student version? He needs
to give me a grade of my work for this course on university. How can I
solve that problem? Maybe it could be because of the differences
between the versions. I've created the file with AutoCAD 2016 and he
uses 2015. I've sent him LT2013, LT2010 and .dws but he is not able to
open the files. I've installed DWG True View to convert the file but this
message occured: "Conversion Errors Unconverted files: The files
listed below could not be saved due to a sharing violation or disk
write problem." Please help me.
Regards, Nadine
¡Resuelto! Ir a solución.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
2016 and 2015 do use the same DWG file format, so he should be able to open your drawings without any issues.
The most important question is: when your tutor tries to open the drawing, which message does he get (exactly)?
Sometimes it could be a problem of transport (traffic through internet) or an antivirus software blocks the transport or opening the file, there are a lot of possbilities.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
hi Alfred,
the message that he gets is:
"drawing file is not valid"
I had to translate the message into English.
This is the word by word translation.
The original message is
"Zeichnungsdatei ist nicht gültig"
-Nadine-
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
>> The original message is "Zeichnungsdatei ist nicht gültig"
Nun denn, dann auf deutsch
(es gäbe >>>hier<<< auch ein deutsches AutoCAD Forum)
Wenn Du AutoCAD 2016 hast und Dein Tutor AutoCAD 2015 hat, dann verwendet Ihr das gleiche DWG Format und es gibt keinen Grund, wieso "Zeichnung ungültig" kommen könnte, zumindest kein Grund, der etwas mit den AutoCAD Versionen zu tun hat.
Damit folgere ich:
- Dein Gegenüber hat kein AutoCAD 2015, dann wäre die Frage, welches Produkt und welche Version verwendt wird, um Deine DWG zu öffnen
- Die Datei ist tatsächlich kaputt, defekt auf dem Weg durch Mail oder blockiert durch Antivirus-Software, um das zu verifizieren könntest Du die Datei hier mal zur Verfügung stellen, dann kann ich hingucken, und damit prüfen, ob Du als Sender der Datei ein Problem hast oder der Empfänger ein Problem hat.
- alfred -
Alfred NESWADBA
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Er hat mir versichert, dass er AutoCAD 2015 benutzt, aber überprüfen kann ich es sicherlich nicht
Hier ist die Datei. Bin mal gespannt ob Du sie öffnen kannst.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
AUDIT command found two errors in your file, but it opened fine in AutoCAD2015-2016 here.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Es tute mir leid, Meine Deutsch ist slecht
viellichet machen datei alter? etwa 2010
Ich kann dir datei offnenkein problem.
CADnoob
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Same for me, opening your file works well.
So my guess the tutor has to check his side.
How have you sent the file, using mail or USB or copied on some FTP? Try to go another way, maybe you have AutoCAD workstations anywhere close to your tutors place to try your file side-by-side. At least you can tell him that all of us were able to use your file.
- alfred -
Alfred NESWADBA
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Thanks to everybody! I am excited that my file could be opened.
I've sent the file via email to my tutor. I don't know what the
problem is actually but I think I'll bring my laptop with the drawing
to his office.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
So to complete this discussion, I came to the conclusion that sending the file by e-mail was the problem.
When I brought the file on an USB to my tutor's office it could be opened without any objection.
Thanks anyone for helping me!
Nadine
