500 Vistas, 8 Respuestas
Creating another custom block
OK - thanks to help from here I was able to get the previous block using visibility states created.
Now I am working on another block.  It is a variation of the "Tag - Imperial" that comes with Autocad.  The only difference is that instead of one piece of text in the circle I want two pieces separated by a horizontal line (like what you see inside the circle of the standard "Callout Bubble - Imperial"  I have the lines laid out, and the text set up.  I have a polar stretch applied and the line rotates around the center of the circle as it should.  But I have two problems.  The grip on the end does not travel and stay with the line and the grip at the center of the cricle does not stay with the center of the circle either.  So if you move either of these grips, it falls apart.  How do I create anvhor points for these grips in the Block Editor?
Current version attached as "Tag Test.dwg".
Thanks!
