03-07-2016
07:34 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
03-07-2016
07:34 AM
Its not a bug. THe reason they don't move back is that their position has been changed manually. The text placement is not at the extension line like you would see in a style but rather aligned with the end point per user input. so when you change styles the style is applied and then the manual user positioning overrides the text style. This is why it does not behave this way when new constraint dimensions are added. To fix the current drawing all you need to do is to remove the manual positioning of the text. after that it will behave like you were thinking it should.
CADnoob
