5475 Vistas, 3 Respuestas
03-03-2016
03:12 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
03-03-2016
03:12 AM
Hallo! In studio we have two PC with Autocad 2015 installed. Yesterday we realized that the RGB values of the "pre-set" grey (250-251-252 etc) aren´t matching! Example: for Grey 250 i have the following RGB values ( correct i think) : 51,51,51; meanwhile the other machine´s value is 0,0,0! And this works for all the grey on this machine: gray 251 is 101,101,101 and Gray 252 is 102,102,102. Pretty strange ah? Thanks for the help! Carlo
¡Resuelto! Ir a solución.
03-03-2016
03:48 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
03-03-2016
03:48 AM
This depends on the background color setting in AutoCAD, look to command _OPTIONS ==> tab Display ==> Colors.
Be also careful that 2D-modelspace and 3D parallel or 3D perspective projection can have different backgrounds.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Alfred NESWADBA
03-03-2016
05:34 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
03-03-2016
05:34 AM
Thank you sir! Worked properly...only one question: why does autocad have this behavior?
03-03-2016
06:00 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
03-03-2016
06:00 AM
I guess this was done ages ago when AutoCAD learned to use a background color other than black.
The intention I think is that 255 was (for black background) real white ... and now, beeing able to use white background, it had to be modified so you can see objects with that 255-white even when working with white background.
But that's only guessing.
- alfred -
Alfred NESWADBA
Alfred NESWADBA
