BrochuAD211
331 Vistas, 3 Respuestas
Autocad 2015 tool window font problem
Hi!
I have this issue with the font in the tool windows in Autocad 2015 runninng on windows 10
Anyone knows how to solve this?
Thanks alot!
Alfred.NESWADBA
en respuesta a: BrochuAD211
welcome @Anonymous.autodesk.com!
You have set the Windows font-size to another value than 100%, that results in some text objects are DPI.scaled, some not.
You can also look to these search/tag-results >>>click<<<
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
BrochuAD211
en respuesta a: Alfred.NESWADBA
Hi!
Thanks for the solution.
Unfortunately it didn't work... I restarted my computer (and obviously AutoCad too) after applying the changes, without succes.
Could thia problem be related to the font used by windows? If so does anyone knows how to change it?
Thanks in advance!
Enviado desde Outlook Mobile
Alfred.NESWADBA
What do you mean by "it"?, I sent not just one suggestion, the search result shows links to many threads with different suggestions also holding themselves (sub)links to other threads.
So what have you tried from all of them?
- alfred -
Alfred NESWADBA
