krishnandynBQY9Z
190 Vistas, 3 Respuestas
autocad ltscale hidden linetype problem
Dear All,
I face the problem of ltscale for hidden type only.
Always hidden linetype having some problem,
I set celtscale=1, psltcale=0 msltscale=0 ltscale=500 dimscale=50.
centreline is ok. i dont want to change seperate ltscale for hidden lines only.
Please find attached.
Krishna
Valentin-WSP
en respuesta a: krishnandynBQY9Z
@krishnandynBQY9Z ,
Check the attached file.
If you are working in metric, use the acadiso.lin.
Also, consider setting your Global scale factor to 25.4.
(Related: How to change or convert the units of a drawing in AutoCAD products)
Lastly, make sure your Linetype scale Properties are set to 1.
BEFORE (small portion)        AFTER (small portion)
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
Emilio Valentin
coolkris
en respuesta a: Valentin-WSP
Hi
But ltscale is supposed to be 10 times of dimscale. I had been taught for long time. Also how drawing limits affect the scale factor in general.
Krishna
TomBeauford
Controlling Linetype Scale is as Easy as 1,2,3! https://www.cad-notes.com/controlling-linetype-scale-is-as-easy-as-123/
64bit AutoCAD Map & Civil 3D 2023
Architecture Engineering & Construction Collection
2023
Windows 10 Dell i7-12850HX 2.1 Ghz 12GB NVIDIA RTX A3000 12GB Graphics Adapter
