12-22-2024
09:09 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
12-22-2024
09:09 AM
@Kent1Cooper wrote:
..... Would it be acceptable to not round those corners...? That would be the easiest to define. ....
For example, the TEST pattern definition in the attached TEST.PAT file [you'll have to un-Zip it -- the site doesn't allow attachment of .PAT files] makes this:
It will need to be longer if you want the squares' corners chamfered or "rounded."
The hexagon edges are 1 drawing unit long when used at a scale of 1. The origin is in the middle of a 45°-angled square / middle of a hexagon.
You will probably want a different pattern name. If you leave it in a file of its own, make sure the file name [minus the .pat filetype ending] exactly matches the name of the pattern inside the file.
Kent Cooper, AIA
