Kent1Cooper
en respuesta a: TheCADnoob
@TheCADnoob wrote:
.... Once you have the items traced you can use the surface tool to create surfaces of everything, then you can extrude the items. once you have 3D solids you can use the subtract tool to create your 3D Model. ....
Easier than that:  Once you have it traced, assuming the perimeter and all the internal triangles/quadrilaterals are closed shapes, PRESSPULL will make the whole 3D Solid with all the holes in it, all at once.  No need for Extrusions of a lot of pieces and then Subtracting those from an overall Solid.
Kent Cooper, AIA
