- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
hello, i have a 1:1 siteplan that i drew with meters as the units. i need to print at a 1:250 scale, however whenever i try to do so in the layout tab, it is incredibly small even on a 11" x 8.5" paper. i'm not entirely sure if i'm doing something wrong, or if it's the scale i am using. i have attached the dwg file if that is helpful. thanks!
¡Resuelto! Ir a solución.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Since you're drawing in Meters in Model but your Layout is using units in Millimeters then this is your ScalelistEdit factor for 1:250:
To see more of your large site plan I would use 1:1000 then your ScalelistEdit factor would be this:
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
I think you should be using a scale of 1 to 2500.
At a scale of 1 to 250, you would not get your scale bar (lower right hand side of drawing) onto an A1 sheet.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
thank you, i'm testing out the 1:2500 scale as you showed in your message, mine isn't filling the A1 page. have i done something incorrect in the provided screenshots? i do need the siteplan printed on a page size that adequate for drawing over with tracing paper. thank you again.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
As I responded previously, setup a layout for each different scale instead of changing the PLOT window's scale...leave that at 1:1
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
you are welcome and thank @richard_387 for contributing to the answer...cheers!!!
