12-12-2024
10:35 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
12-12-2024
10:35 AM
1) yes, while 3/4" was the active scale of CANNOSCALE
2)Block is inserted via a tool palette. Using the CLASSICINSERT command the block behaves appropriately as long as I edit the attributes to be non-annotative within the block
3) Attached drawing, Side note, this only affects blocks with attributes, it does not happen with other annotative objects such as dimensions. It's annoying because If I am working with 2 scales (3/4" and 1/2") when I change my CANNOSCALE accordingly, I can no longer read objects on the previous scale because they will default to 1:1 for anything not on the currently active CANNOSCALE
