- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Greetings Autodesk Community,
I have a customer that needs both the "Handle" and "Anonymous Name" data to populate in a Data Extraction for some Blocks.
When I use the 'List' command on one of the Blocks that I am working with, I can see both the Handle and Anonymous Name, but these fields do not populate when I run a Data Extraction with all fields turned on and checked.
Do any of you know how to get these two fields to populate within a Data Extraction or another way to get all of the needed attributes from the Blocks AND these two fields to populate in a report/spreadsheet?
Thank you in advance,
Morgan.
¡Resuelto! Ir a solución.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
V1) Use ATTOUT instead of DATAEXTRACTION (if you don't need dynamic properties values)
V2) No, there is nothing ootb (see V3)
But for your own standard blocks in future: Add additional attributdefinitions
and paste this fieldcode as default:
Blockname: %<\AcObjProp.16.2 Object(?BlockRefId,1).Name>%
Insert Handle: %<\AcObjProp.16.2 Object(?BlockRefId,1).Handle>%
(copy it from notepad and paste it in AttDef dialog / default)
Insert a new blockreference (or run Attsync for existing ones)
Run DataExtraction
or
V2) Use another tool to extract what you need. I can't think you will find one ready to use,
but if you have the source code of this tool (Lisp source code for example) and it is allowed to edit
this code for you, it's easy to add Handle/Name data
Sebastian
