02-29-2016
08:38 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
02-29-2016
08:38 AM
@Anonymous
Can you post your drawing to the forum thread?
Did you get this error after running the suggested commands?
It would be helpful if you provided more information to better assist you with your issue in AutoCAD?
Try running the followng file clean up steps;
- (-)PURGE > Regapps > Enter>No
- (-)PURGE>ALL> Enter>No
- AUDIT> Yes
- PURGE > Select Purge nested items> Select Automatically purge orphaned data > Purge All
- CTRL+A > OVERKILL (Warning: running the command modifies your geometry by deleting objects you might need in your structure)
- Close and Save newly purged file (ex. CLEANED_file)
- Apply workflow.
Sarah Emmsley
Technical Support Specialist
