pendean
en respuesta a: wse_stacey
So... can you see the markups on your PC PDF viewer/editor?
Can the boss do the same on their PC/Laptop?
"suddenly" means you are doing something completely different: what is that? I can't tell from your post if you tried that yet.
If you PLOT and PUBLISH to the same exact Autodesk provided PDF driver, they should be identical in output. It would appear you may not be doing so.
Turning PDF markups on/off is done at the PDF driver level (not an option in Autodesk provided drivers) as well as in the reader/editor that is opening those PDF files (you don't mention if the Boss is exploring there too).
