valonsoiglesias
en respuesta a: AutoMarcus
Hit Key icon on command bar... select "input search options" and reduce on the very down left the option of "suggestion list delay time" to 100 (300 should be the default one)... press okay and happy days...
The problem is when you move the command bar or reduce the size, so it is let's say detached... that is where the problem comes from in cas it has started to stop working you space key...
